It is currently Mon Jun 15, 2026 6:55 am
Post new topic Reply to topic  [ 11 posts ]
 Post subject: 列印機翼表皮的$
PostPosted: Thu Jan 20, 2005 12:25 am
我正在找尋一個可以列印機翼表皮的軟件,請大家題供意見。
我睇過一些印 airfoil 的軟件,如 Compufoil 及其它同類型的 program。
它們都可出魚仔,但係就出唔到張皮。
我想用 vacume bag 方式造机翼,打算將個翼型印出黎,再用 Mylar剪個外型出黎。
然後落玻璃仟維去 bag。
有冇人可以幫到我?
謝謝!
PostPosted: Thu Jan 20, 2005 9:37 pm
Do you think 'Profili" works for this task? I'm not sure!
PostPosted: Fri Jan 21, 2005 2:04 am
Ah Mak,
Are you making a new weapon? ME TOO :twisted:
For vacuum bagging, I think the mylar leading edge must need to match the foam, while the trailing edge needs not, and so the mylar is actually larger than the foam. And since vacuum bagged wings usually have straight leading edge, does it necessary to print out an accurate wing planform?
As you asked, I think you must have your reason. Top secret weapon??
PostPosted: Fri Jan 21, 2005 11:31 pm
The leading edge is not straight. That's the problem !
I tried both Profili and Compufoil, but they don't do what I need !
PostPosted: Wed Jan 26, 2005 1:11 pm
Ah Mak, what sort of wing you try to work out this time, DLG or F3F, I have a blue foam wing core with AG45-46-47, and I do not think I will bag it, if you are interesting to do the bagged before you figure out the wing plan drawing method, ring me whenever you like, Patrick
PostPosted: Sat Jan 29, 2005 5:18 pm
Hi Patrick,
Thank you for the offer.
I have no problem with the foamcore. It's the skin templet, which I couldn't workout!
PostPosted: Mon Jan 31, 2005 6:50 pm
Ah Mak, you mean you cannot work out the plan of the AG airfoil wingspan? Patrick
PostPosted: Mon Jan 31, 2005 9:00 pm
I'm going to bag the beetle, which have complex core shape. The wing core is constructed with 6 foam sections.
I need to cut mylars to match with the composite wing layup. which should cover the wing surface area exactly. What I can do now is to lay a sheet of transperent paper on the wing, and sketch the shape with pencil, but the results are not very good!
The bagging will be an easy job, if I can find a program to print out the top and bottom cover sheets for the many sections of the beetle !
If I can get the beetle to work, there will be no difficulty for any other wing layup jobs!
PostPosted: Mon Jan 31, 2005 10:11 pm
Dear Mak,
Great to hear that you are back to construction work from business. I saw you cutting the foam core, and I would be most grateful to see how you bag the wing. Please give me a call when you are ready.
Regards.
(Sorry for I could not help for figure out the programme)
PostPosted: Tue Feb 01, 2005 1:11 pm
Ah Mak, the most simply way I can figure out is the same as yours, but I will choose to use the bottom or the top piece which cut out from the core, they should be exactly the same as the core, right? Patrick
PostPosted: Tue Feb 01, 2005 8:17 pm
Yes, you are right !
I think that's what I'll have to do !
Users browsing this forum: No registered users and 7 guests
