It is currently Sun Nov 08, 2026 3:13 am
Post new topic Reply to topic  [ 196 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Tue Sep 14, 2010 3:38 pm
Angus,
Please check rather you can use this web base score sheet from your mobile phone.
Thank you!
http://www.editgrid.com/user/i4kai/Scor ... ersion_V2a
Hi Mak
My phone will serve as wirelrss router to let other access to internet. As long as other pilots' phone or iPad can read, there should be no problem.
Angus
PostPosted: Tue Sep 14, 2010 7:19 pm
Angus wrote:
Angus,
Thank you!
Hi Mak
Angus
但人人都edit 到, 要睇吓點set 番 read only
PostPosted: Tue Sep 14, 2010 8:32 pm
This one is for testing, so doesn't matter.
It can be set to READ ONLY when it's for real.
PostPosted: Wed Sep 15, 2010 8:08 pm
蘇師傳! 會否在開賽前玩返合法頻率通話機!
因為我地好多人現在都用以前的那個頻率!
PostPosted: Thu Sep 16, 2010 12:31 am
因為我地好多人現在都用以前的那個頻率!
會盡快換取一批合法频道對講機。
PostPosted: Fri Sep 17, 2010 10:25 am
上次會議咪講魚記要我哋要有急救人員在場
不如我哋call st.John 去當更啦,我哋可以理少樣
還有三星期立即入紙仲有機
http://www.stjohn.org.hk
http://www.stjohn.org.hk/b5/af/af_firstaid.pdf
傳真致2530 2727或電郵 brigade@stjohn.org.hk
PostPosted: Sat Sep 18, 2010 1:01 am
非常榮幸,我請倒我愛人來幫手,8號可以,她只懂做Point B judge.
PostPosted: Sat Sep 18, 2010 11:12 am
統計一下現時Helper人數:
8-10號全場攝影師 - Hendry
8號 - 亞華, Donny's朋友, 小廣愛人, 麥太
9號 - 亞華, Donny's朋友x2, 麥太
10號 -亞華, Donny's朋友, Steve, Ken28
Ken28- 9號 maybe ok,
小權 - 8或9號其中一天.
我們每天最少需要4位線審, 請各位盡量抽空幫忙,
或幫手找致愛親朋扙義,不勝感激.
謝謝
PostPosted: Sat Sep 18, 2010 2:52 pm
My wife can be Point B judge or marker, on Friday & Saturday.
also Sunday if really required.
PostPosted: Wed Sep 22, 2010 12:00 pm
請問有冇飛友係6號星期三得閒去放機?因為有些外國參賽飛友會提早6號到,想上山練習,如果有飛友幫忙帶他們上山就好啦!
PostPosted: Wed Sep 22, 2010 1:43 pm
Sorry, 我7號星期四才開始放假.
PostPosted: Wed Sep 22, 2010 5:41 pm
donny wrote:
統計一下現時Helper人數:
8-10號全場攝影師 - Hendry
Ken28- 9號 maybe ok,
小權 - 8或9號其中一天.
或幫手找致愛親朋扙義,不勝感激.
謝謝
小權 - confirm 8號 ok.
PostPosted: Thu Sep 23, 2010 1:40 pm
donny wrote:
統計一下現時Helper人數:
8-10號全場攝影師 - Hendry
Ken28- 9號 maybe ok,
小權 - 8或9號其中一天.
或幫手找致愛親朋扙義,不勝感激.
謝謝
小權 - confirm 8號 ok.
我同 Henry l0號 〇K
PostPosted: Fri Sep 24, 2010 9:08 am
donny wrote:
統計一下現時Helper人數:......
非常多謝各位熱心幫忙,
Helper 人數更新如下:
8-10號全場攝影師 - Hendry
8號 - 亞華, Donny's朋友, 小廣愛人, 麥太, 小權
9號 - 亞華, Donny's朋友x2, 麥太, Pauline
10號 -亞華, Donny's朋友, Steve, Ken28, Vincent, Henry.
Ken28- 9號 maybe ok.
PostPosted: Wed Sep 29, 2010 9:41 pm
Hi Donny,
Pauline (my girlfriend) will come to help on Saturday.
Besides, my best friend (Fu Chai that you met in Taiwan) will fly over to help as well.
PostPosted: Sat Oct 02, 2010 10:37 pm
It's getting a bit worrying for the weather forecast by WindGURU! :cry: :cry: :cry:
Predicted heavy rain in Thursday although with strong easterly wind.
Wind direction will switch to northerly and weaken on Friday! :oops: :oops:
and remain weak northerly on Saturday! :oops: :oops:
Anyway, HKO forecast is still ok for moderate to strong easterly wind through out. :lol: :lol: :lol:
Which forecast, Windguru or HKO, is more accurate?
I hope HKO of course, let's pray! :x :x
PostPosted: Mon Oct 04, 2010 10:08 am
Another source shows a promising weather :D
http://www.dryday.com/hong-kong/ma-on-s ... -forecast/
Thanks YC :lol:
PostPosted: Mon Oct 04, 2010 11:27 pm
http://www.hko.gov.hk/wxinfo/currwx/fndc.htm
從天氣預報看來是, 星期五, 六, 曰都會下雨? 好擔心啊...
PostPosted: Tue Oct 05, 2010 1:19 am
不用太大擔心,10月時份的雨應該不會大,只要有避雨帳篷,短暫的陣雨不是問題,風況應該不錯!上次5月的Viking賽也是落了些陣雨,雨停後也是繼續賽,無問題! :lol: :lol: :lol:
PostPosted: Tue Oct 05, 2010 10:04 pm
大戰前夕的沉寂,氣紛開始緊張!
繼續密切留意天氣的變化!
風況和雨況似乎有很好的趨向,除了星期五可能有幾陣雨外,星期六和星期日都應該無雨,而且風速都有6、7米秒以上!
各位飛友,如果你們有避雨的帳篷,請星期五帶出來以備不時之需!
PostPosted: Tue Oct 05, 2010 10:15 pm
各位飛友,
TR2010賽最後參賽者出賽的次序表在此
http://www.hkrcss.org/HKF3F/pilot_list.pdf
第一個飛的賽手號碼將會在星期五早上用抽簽決定。
嘩!原來我被編在台灣小黑之後,睇住佢飛得咁快我咪好大壓力! :roll: :twisted:
PostPosted: Wed Oct 06, 2010 12:02 am
東 北 季 候 風 今 日 持 續 影 響 華 南 。 本 港 方 面 , 今 日 多 雲 及 有 幾 陣 雨 , 大 嶼 山 及 市 區 錄 得 數 毫 米 雨 量 。 同 時 , 位 於 海 南 島 附 近 的 低 壓 區 今 日 增 強 為 一 熱 帶 低 氣 壓 , 與 其 相 關 的 外 圍 雨 帶 為 華 南 沿 岸 及 南 海 北 部 帶 來 有 雨 的 天 氣 。
在 晚 上 十 一 時 , 該 熱 帶 低 氣 壓 集 結 在 三 亞 之 西 北 約 120 公 里 , 預 料 向 西 北 偏 北 緩 慢 移 動 , 橫 過 北 部 灣 。 預 料 該 熱 帶 低 氣 壓 的 外 圍 雨 帶 會 在 未 來 數 天 持 續 影 響 華 南 沿 岸 。
本 港 地 區 ( 十 月 六 日 , 星 期 三 ) 天 氣 預 測
多 雲 , 有 幾 陣 雨 。 氣 溫 介 乎 22 至 25 度 。 吹 和 緩 偏 東 風 , 離 岸 海 域 風 勢 清 勁 。 海 面 有 湧 浪 。
颱風賽真是有個微型颱風來增慶。 :twisted:
PostPosted: Wed Oct 06, 2010 4:04 am
請現在保管着F3F timer和線的人,明天十月六日一定要交給我作最後檢查,我明天下午在馬鞍,晚上在麗豪,Thanks !!
