It is currently Mon Nov 16, 2026 5:28 pm
Post new topic Reply to topic  [ 20 posts ]
PostPosted: Tue Nov 13, 2007 1:04 pm
Hey hey, don't just play f3f, DS, thermal :!: Now you can try fly yourself up in air :o
Take a look into www.ymca.org.hk :o
香港史上前所未有的「無動力」慈善人力飛行大賽 :o
Deadline for enrolment : Nov 19 :idea: Hurry Hurry :o
PostPosted: Tue Nov 13, 2007 2:32 pm
Quite interesting! Anybody want to join and form a team to apply our creativity?
PostPosted: Tue Nov 13, 2007 3:36 pm
Hi Big Yeung,
Have you checked the rules? It is mission impossible.
4.5 飛行器具之特色及設計限制
用以「比賽」之飛行器必須以純人力推動為設計及制造之原則,並符合以下之要求:
4.5.1 長度: 飛行器之最大長度不可多於三米。
4.5.2 翼及翼長: 飛行器之最闊長度(包括兩翼)不可多於三米。而翼之設計可固定、可轉動或上下
拍打,但翼的旋轉幅度也不可多於三米。
4.5.3 高度: 飛行器的高度不可多於三米。
4.5.4 發射裝置: 飛行器不能以任何輔助性的發射裝置來加強其飛行距離。
(例如單車滑輪、路軌、拖拉之車或船,甚至「力士團」等均不可使用)
4.5.5 提升裝置: 參賽者不能利用汽球、風箏或降落傘等來令飛行裝置可以浮升。
4.5.6 利用外置能源:所有額外的能源均不可使用,例如壓縮氣體、彈簧、橡筋、氣體推進器等。
4.5.7 滑輪、螺旋槳或摩打
- 如以人力發動之裝置如滑輪、齒輪及螺旋槳亦可加入在飛行器具的設計中。
- 所有摩打及引擎均不允許使用。
4.5.8 重量:飛行器的重量不可多於參賽飛行員體重的百分之五十。
3m Wing span. Think about holding your Aris or Trinity and jump down from Ma On Shan . . . Committing suicide is illegal in Hong Kong.
PostPosted: Tue Nov 13, 2007 4:09 pm
Hi Big Yeung,
4.5 飛行器具之特色及設計限制
4.5.2 翼及翼長: 飛行器之最闊長度(包括兩翼)不可多於三米。3m Wing span. Think about holding your Aris or Trinity and jump down from Ma On Shan . . .
It's not a glider contest. It's a man powered airplane.
I bet we can make a flying wing with 3M wing cord, with a large propeller at the front.
The man can sit under the wing on a light weight bicycle to power the propeller.
While on the ground, the bicycle can push the wing forward. As soon as the planes on air, the propeller will pull the whole thing along.
The wing should have a low speed airfoil, which generates maximun lift.
The man will have to move himself fore/backward to balance CG.
Anyone want to try?
PostPosted: Tue Nov 13, 2007 4:36 pm
Hi Mak,
I remember that I read some articles about man-powered aircraft. Reserch showed that it is impossible for human to lift by himself using his own muscle to fly like a bird (flapping wing, rotary wing, etc). The power/weight ratio is too low for human than the birds.
The only possible man-powered flying is to use a large lift generating device. i.e., a big wing.
Just talked with Ah Kin. We think that the only possible way to win under the rules are two big springs. Put them on your feet and jump as far as you can. :) :)
PostPosted: Tue Nov 13, 2007 4:51 pm
Hi Mak,
The only possible man-powered flying is to use a large lift generating device. i.e., a big wing and the hight of the starting point.
We may not be able to fly for long distance, but 100M is possible depending on the efficency of the wing 8)
PostPosted: Tue Nov 13, 2007 5:05 pm
The jumping stand is only 1.8m high. For 100m the glide ratio is 55. Only a few high performance sailplanes can approach this number.
75Kg on a 3m wing? Impossible !!!! :!: !! :!: !!!!!
五. 起飛平台
5.1 水上篇之起飛平台
- 高: 約1.8 米(離水面)
- 跑道面積: 約5 米(闊)乘25 米(長)
5.2 陸上篇之起飛平台
- 高: 約1 米(離地面)
- 跑道面積: 約3 米(闊)乘10 米(長)
PostPosted: Tue Nov 13, 2007 5:40 pm
Contests date Dec 16 for the Marine contest may be very cold. I guess not many people will joint that section.
PostPosted: Tue Nov 13, 2007 6:00 pm
It is impossible to fly long distance without machine help!!!!They are only 3meter long for the span and 1.8 high limited !!! I think they fly not over 4-5meter only!!!!No interesting!!
PostPosted: Tue Nov 13, 2007 7:46 pm
Check here :
http://www.skytec-engineering.de/hpa.htm
and these :
PostPosted: Tue Nov 13, 2007 8:17 pm
Got a few phone calls this afternoon asking for more details about this event :idea: Seems not everyone able to open the pdf file from the website :?
Here are some details:
Event name: A 1st ever human-powered charity flying competition in the history of Hong Kong
Inquiries: YM Concept, Chinese YMCA of HK, 23 Waterloo road (very close to Ah Kin's shop :x)
Key dates:
a. Deadline for application : Nov 19
b. Briefing session : Nov 22 (at YM Concept)
c. Marine Contest : Dec 16 (9am to 17pm) at Gold Coast Yacht and Country club HK
d. Land Contest : Dec 23 (13pm to 17pm) at City Walk, No 1, Yeung Uk Road, Tsuen Wan
Groups:
1. Mini Birdman (for age 3 - 11), just show no need to fly
2. Youth group (for age 12 - 18)
3. Open group (for age 18+)
** World record by UK in 1992 for 89.2 meters **
Awards:
1. The HK Birdman Award 2007
2. The Best Birdman Costume Design Award
3. The most popular Birdman Award
Hurry hurry :o
PostPosted: Tue Nov 13, 2007 9:02 pm
Just check the official webiste of Bognor Birdman contest in UK. The allowable wing span is 30 feet (9.14m). Even with this wing span, the contest record is 82.5m only! Thus, I don't think the contest organiser have any concept on aerodynamic.
PostPosted: Tue Nov 13, 2007 9:35 pm
Hi Mak,
Do you mean this ?
but that is jumping. Not flying :!:
PostPosted: Tue Nov 13, 2007 9:39 pm
This event will held in "City Walk", Tsuen Wan. Is this just a shopping mall? If so, I guess the orginizer just expect us to glider a few meters, or it's simply a "3 steps jump" event in sports.
PostPosted: Tue Nov 13, 2007 10:42 pm
真係唔知賽乜野!!賽意念?賽跳遠?賽科技?一頭霧水!!
啊麥post出泥果D當然好正,但佢地根本無呢科.比佢地啊媽知道飛上天,打到飛起就有,仲有年紀只有十幾歲,鬼識飛咩,我地都仲勉強夠胆飛,佢啊媽見倒個仔飛咗出去,一定當場云倒地上!!我覺只有一D大公司,大學先會玩呢味野!!一隻呢D機材料不少於2-3萬蚊,都係買3F機算喇!!
PostPosted: Wed Nov 14, 2007 9:56 am
It should be considered as a show, a tesing on falling with drag :shock: . That's what I mentioned with 'creativity' but not gliding or flying. :D :lol: :lol:
PostPosted: Wed Nov 14, 2007 11:57 am
The organiser should consider more on the safety side, especially on the Land contest. when the Birdman drop from 1 meter height, he may not touch ground in the expected orientation. The installed wings may hurt the birdman's hand or body easily, even if there are protection equipment.
On the Marine section, case will be even worst. Once the 3m wing touch the sea surface, it will stop immediately, but the bird body will keep move, this is the most dangerous part.
I am happy to see this contest, but organising it safely and properly is not easy. I think all the Birds will fly their FIRST and their ONLY flight on that day, nobody can tell what will happen.
PostPosted: Wed Nov 14, 2007 1:06 pm
The 3m wing span limitation is quit challenging :x I did some rough "guesstimation":
The following is the well known lift equation.
L = Cl * p/2 * V^2 * A
L is the lift of the wing. Assume that we have the pilot weight 50Kg, and the aircraft weight 25Kg. The lift required is 75Kg * 10m/s/s = 750N. (For 25Kg aircraft, I think it is very difficult to make for the wing + bicycle + propeller mechanic)
Cl is the lift coefficient. It depends on the operation conditions of the wing (Reynold number, attack angle, etc). Clmax of our model sailplanes is around 1. Typically it is operating at 0.4-0.5. The maximum Cl is about 3, by a very thin and cambered airfoil. which cannot be built in real world.
Since the aircraft is probably a tailless design, a reflex airfoil is required for pitch stability. I chose the MH91 for design example. MH91 is designed for paragliders, the operating Reynold number should be similar to the man-powered aircraft. The Clmax of MH91 at Re 2.5x10^6 is 1.4. Note that at Clmax the wing is operating at the maximum attack angle, Cl/Cd is low and the most important is: it is about to stall. Lets take Cl=1 which still have about 5 degree attack angle before stall.
p is the air density = 1.2kg/m^3 at sea level.
V is the velocity of the wing.
A is the wing area. A is maximum if the wing chord is 3m. (And we will have a strange wing of aspect ratio = 1 ! :!: !) Note that the lift distribution on a rectanglur planform wing is elliptical. The lift at the wing tip is zero. (So for efficiency, wings of our models are tapered to an elliptical planform). Assume the lift is still 100% at 80% span, the effective wing area is 7.2sqm.
Then we can calculate the minimum flying speed to generate 750N of lift:
750 = 1 * 1.2/2 * V^2 * 7.2
V = 13.2m/s or 47km/h
Check the Reynold number: Re = 70000 * 3 * 13.2 = 2.8*10^6. No problem!
The above calculation is very rough and there are many factors have not been taken into account. For example, the extremely short wing should be greatly suffered from the tip wash and reduce the lift. So I guess, the flying speed must be well over 70km/h to generate enough lift. 70Km/h, well, at least not possible for my own muscle! :)
PostPosted: Wed Nov 14, 2007 9:15 pm
留番D精神同時間補下機好過啦 :lol:
PostPosted: Mon Dec 17, 2007 12:59 pm
http://appledaily.atnext.com/template/a ... coln_id=20
From 蘋果日報 2007-12-17:
禽 流 感 當 道 , 無 礙 一 班 香 港 人 大 發 飛 行 夢 。 黃 金 海 岸 噚 日 舉 行 本 港 首 次 人 力 飛 行 比 賽 , 21 隊 參 賽 者 鳥 人 合 一 , 用 盡 方 法 , 飛 得 幾 遠 得 幾 遠 , 場 面 惹 笑 。 比 賽 分 兩 大 項 目 , 一 項 係 鬥 造 型 , 另 一 項 係 鬥 遠 。 「 最 佳 鳥 人 造 型 設 計 獎 」 由 「 TTs : 鳥 人 的 誕 生 」 隊 奪 得 , 參 賽 者 將 個 貼 滿 花 紙 巨 型 蛋 殼 笠 上 身 , 化 身 雞 蛋 人 , 成 為 史 上 唯 一 識 飛 雞 蛋 。
至 於 鬥 遠 比 賽 , 由 「 愛 與 夢 飛 行 」 隊 以 8.6 米 奪 得 「 2007 香 港 鳥 人 大 獎 」 冠 軍 , 參 賽 者 摺 隻 巨 型 紙 飛 機 , 套 頭 上 , 然 後 用 盡 氣 力 , 一 飛 天 就 冇 佢 份 , 結 果 一 飛 落 海 , 不 過 佢 彈 跳 力 驚 人 , 畀 佢 彈 到 好 遠 , 勇 冠 全 場。
:o That's our prediction: "JUMP FAR" is the correct strategy to win this game :o
Users browsing this forum: No registered users and 19 guests
