It is currently Tue Nov 17, 2026 9:43 pm
PostPosted: Sat Jan 12, 2008 12:15 am
Read a consummer report in todays am730.
Casio is going to interduce a new DC camera (that looks like a DSLR) in March for us$999.
The movies specification is very high:
1920 x 1080 Full HD with 60fps, supporting HDMI. 12x optical zoom (big f2.7-4.6 len)
My old Casio DC had good movies, but there is a big dust on the sensor making it usless.
I expect this new camera to be better than my old one!
( THIS IS NOT AN ADVERT ) :lol:
PostPosted: Sat Jan 12, 2008 1:47 am
Mak, I have the same Casio DC as yours.
It is very easier to clean the sensor. I have done so by taking off the casing and unscrewing a few screws, but you have to do it quick in order not to introduce more dusts.
PostPosted: Sat Jan 12, 2008 9:33 am
You really unscrewed your DV camera, did the repair and put it all back together to operating condition :shock: :shock:
Tell you what!
I feel so hopeless with it; I put my DV into a water tie bag, into an ultrasonic bath tried to dislodge dust from the sensor. :oops:
You have to show me how did you do it :o
PostPosted: Sat Jan 12, 2008 10:03 pm
Yes, of course, I did, but with extreme care!
小心D打開LCD那面既蓋,然後將LCD panel拆下,小心唔好整斷D線,再將個sensor既後蓋拆開(4 口縲絲),半開個位就夠,然後盡快用相機吹塵既風槍係咁吹佢幾
PostPosted: Sat Jan 12, 2008 10:23 pm
:shock: :shock:
以上行為經專人訓練,小朋友在家千萬不可以做呀!!
:roll: :roll:
PostPosted: Sat Jan 12, 2008 10:35 pm
阿邦,你咁得閒不如充定電、早D訓,聽日黎比賽啦!唔係心掛掛,心思思就唔好啦!
PostPosted: Tue Jan 15, 2008 10:32 pm
Thank you for you help.
The sensor is dust free again :D
PostPosted: Thu Mar 13, 2008 10:33 pm
Look at your new movies.h
Your DC camera seems to have dust on the sensor again !
PostPosted: Fri Mar 14, 2008 12:33 am
Yeah! I also discovered that. I think I need to clean it up again.
Funny, I think this is not dusk. I believe it is some kind of moss or bacteria that grow in wet place. I believe two weeks ago when we had the informal F3F in Ma On Shan, we were all wet including my rackset with my camera inside. I didn't dry the camera when I came back home.
Actually, now I remember that the first time I cleaned my camera, it was two or three weeks after I went out to Ma On Shan also under rain and I didn't dry it also. I wasn't sure how this dirt got in last time. Now I know. So make sure to dry the camera after we went out under wet climate!
Now I also suspect that the clash of Aris last Sunday might have the root cause of this wet climate.
My Aris was under the rain for a long time during the informal F3F. I did dry the wing when I got back home, but I left the fuse and the reciever inside untouch. Now I beleive that perhaps the receiver got too much mosture which might have affected the senistivity of the receiving range.
Last Sunday, I did check the receiver and made sure everything move when I launched my Aris. But just after 10 or 15m away from the slope, I lost control of the plane and it seemed that the PCM receiver got locked. There were still tail servo movement after I recovered the plane which means the receiver was still functioning (obviously, may be). So, I suspected my transmitter and checked its range with my Viking, but this was ok. In fact I should have checked the range of my Aris receiver!
I will definitely check the receiver after my Aris backed home after repaired by Ah Pong.
So the story reminds us that we need to dry everything after we had out in the wet for a while! :roll: :roll:
PostPosted: Sat Mar 29, 2008 1:03 am
I checked my receiver in my Aris today after it backed home from a beautiful repair by Ah Pong.
The receiver was confirmed faulty. It has a sensitity of only 10 meters even with my transmitter antenae fully extended!! :x :cry:
I am sure the dam rain did so some demages to the receiver under very wet condition. So make sure to dry your stuff after a wet day out in the slope.
I will open the casing of the receiver to see what's happened inside.
PostPosted: Tue Apr 01, 2008 12:10 am
我拆開裝在 Aris 上個 Futaba R148DP receiver檢驗,抓不到有什麼損壞的踉跡,看來還好新淨!
我估可能裡面的中頻 tuning 有問題,影晌接收靈敏度。請問原廠可不可以回收 re-tune 呢?
今日去偉高想買個 R148DP 8-chan receiver,但阿勝叔話已經無貨,由於 R148Dp 係長條型專為滑翔機設計,已經好耐無人要買,所以都唔再訂啦,我又問過雷記都無貨,請問香港仲有邊度有得賣?外國網站有冇得訂呢?依傢D日元高水,我估起碼都要6、7佰紋至有交易! :twisted: :twisted:
PostPosted: Tue Apr 01, 2008 4:39 am
不如試用 Schulze 8 : http://www.schulze-elektronik-gmbh.com/index_uk.htm, 我都用在 Caldera 上, 無問題 8)
PostPosted: Tue Apr 01, 2008 3:58 pm
試吓問上環德昌,我記得佢好似有賣。
電話: 2857 5021 (1:00pm-7:00pm)
PostPosted: Tue Apr 01, 2008 7:30 pm
今朝一早打電話問左德昌啦,有貨,剛剛上左去買了回來,不過都幾貴,$790 連晶體! :cry:
我都會唸計去調較番隻舊既148DP,無理由掉左佢,最多較番後用係D發泡膠機到囉!
