It is currently Wed Nov 25, 2026 9:08 pm
 Post subject: room for rent
PostPosted: Sat Mar 16, 2013 9:07 pm
hi folks,
I have some space available. what do you think I can do with it ?
I want something unique. Any idea.
8)
 Post subject: Re: room for rent
PostPosted: Sun Mar 17, 2013 1:49 am
To name a few:
30s hieght booster
Auto pilot
Champion finger
PostPosted: Tue Mar 19, 2013 2:17 pm
Variable CG
PostPosted: Wed Mar 20, 2013 4:28 pm
Hi Angus,
Good idea, but how to do it?
I have bought a servo saver, but the height together with a F3102 servo is taller than the canopy. Besides, the travelling distance is only around 12-14 mm. I wonder if other kind mechanism could achieve the same objective.
PostPosted: Wed Mar 20, 2013 5:27 pm
若這是 TR2012 韓戰之巫婆獎,那當然是將空間塞滿泡菜啦!
施主無用多想,信者得救!
PostPosted: Wed Mar 20, 2013 5:28 pm
Ancient linear servo:
http://www.ebay.de/itm/Sammler-variprop ... 460db7c577
or
http://www3.towerhobbies.com/cgi-bin/wt ... LXCJG6&P=7
PostPosted: Wed Mar 20, 2013 5:36 pm
Not new idea: Already used by Vladmir in his F3J:
1 tiny pulley at the end of ballast tube;
2 pull pull wire to slide the snug along the ballast tube
3 use special servo to get 180 deg or more, say programmable servo + program software OR those for robot or sailboat winch (rotates over 1.5 to 2 turns) or landing gear retract.
PostPosted: Wed Mar 20, 2013 10:21 pm
Insert a jet engine la
PostPosted: Mon Mar 25, 2013 2:03 pm
Ah Pong wrote:
hi folks,
8)
Back up battery.
