It is currently Wed Sep 18, 2019 3:56 pm
PostPosted: Wed Jun 02, 2004 6:34 pm
星期日玩過一次都不錯.
(有相Send上來比您們人看?)
地圖:
PostPosted: Thu Jun 03, 2004 8:38 am
什樣去?
PostPosted: Fri Jun 04, 2004 1:07 am
上水華山(有相但唔知怎樣Send上來比您們人看?)
PostPosted: Fri Jun 04, 2004 3:46 am
你e-mail比我,我幫你放上去
 Post subject: 星期六又去尋找
PostPosted: Mon Jun 07, 2004 1:32 pm
這次找到一個東風位在粉嶺,鄰近坪,從地圖尋正確位置.
高度: 235m
*****正確的坪輋東位!!!!!!!!!!
*****更正之前的地圖!!!
呢處有D相:
有興趣Call Me 一齊去玩!
PostPosted: Tue Jun 08, 2004 7:07 pm
PostPosted: Wed Jun 09, 2004 12:36 am
Hello !! Pierre and Ah Pong,
Ah Kam
PostPosted: Wed Jun 09, 2004 1:13 am
:roll: 下次去玩,一定約您們的。
PostPosted: Wed Jun 09, 2004 4:39 am
代客
PostPosted: Wed Jun 09, 2004 5:09 am
真是好地方!大埔有無地點提供?
PostPosted: Wed Jun 09, 2004 9:09 pm
掂的話,我想本週日試坪輋東位,橫掂天氣預告是東風。
PostPosted: Thu Jun 10, 2004 9:40 am
Hi Willy,
PostPosted: Thu Jun 10, 2004 4:22 pm
高度: 235m
PostPosted: Thu Jun 10, 2004 7:26 pm
PostPosted: Fri Jun 11, 2004 6:01 pm
噢,原來地圖未必顯示?
PostPosted: Fri Jun 11, 2004 7:02 pm
PostPosted: Fri Jun 11, 2004 7:08 pm
Billy wrote:
你e-mail比我,我幫你放上去
*謝謝您的幫忙,下次見面請教我* :roll:
PostPosted: Fri Jun 11, 2004 11:54 pm
PostPosted: Sat Jun 12, 2004 1:08 am
PostPosted: Sat Jun 12, 2004 1:19 am
Dear:Rocky
PostPosted: Sat Jun 12, 2004 2:02 am
正確的坪輋東位!!!!!!!!!! :roll:
更正之前的地圖!!!
而南位之前的地圖正確.
PostPosted: Sat Jun 12, 2004 2:14 am
從地圖睇呢個應該是東南徧南風位,並非正東風位!
PostPosted: Sat Jun 12, 2004 4:20 pm
一個山頂有東南北比你玩的!!!
Users browsing this forum: Steve Lai and 11 guests
