It is currently 16 Jul 2018 04:53 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: Aris F3F
PostPosted: 28 Apr 2005 08:01 am
在去年維京賽見到隻 Aris 表現特出,真是恨到留口水,但喺好$$$$$貴,只有忍手。最近聯絡上廠家,可以較平訂貨,我和Angus都己下訂,有冇其他人有興趣?
http://www.f3x.com/htdocs/Aris/aris.htm
PostPosted: 30 Apr 2005 12:35 am
有﹐但如果要 Aris 就唔可以要隻 Viking。
PostPosted: 30 Apr 2005 02:24 am
Y.C.,
我三四個月前已為你訂了 Viking,唔轉得呀!
不過如果你搵到其他機友對 Viking 有興趣可以換機啦
PostPosted: 30 Apr 2005 09:42 am
可唔可以pm我幾$$$呀?
Thanks!
Henry
PostPosted: 16 Aug 2005 06:41 pm
Aris has arrived!
Wow! It's a wonderful plane and beautifully built.
Everything look solid and the construction quality is really high standard.
Two weeks from the coming F3F race, so see whether I can put it up in time.
Ballast set
PostPosted: 16 Aug 2005 09:49 pm
今次F3F唔講得笑,咁多勁機 . . . :?
PostPosted: 21 Aug 2005 02:51 pm
昨天到偉高買了六隻 3102 servos,預備裝砌我隻Aris。聽聞最近這些 servos 好搶手,買到斷巿,皆因最近各路人馬努力砌機備戰 F3F 賽!都是多得阿堅預留這些 servos 給我,不過價錢就很貴呀,加上我架車泊
PostPosted: 21 Aug 2005 11:01 pm
裝坩好電池和開關
PostPosted: 23 Aug 2005 01:33 am
Finished the V-tail servo linkages. Because of the nosecone, space is very tight and I just managed to get enough servo travel after some degree of sanding.
The v-tail is nicely fitted.
PostPosted: 25 Aug 2005 12:41 am
Make the cabling for the Multiplex plugs
Installing the plug
PostPosted: 26 Aug 2005 01:49 am
Fitted a Multiplex plug on the wing - my workmanship is a bit .. ha .. ok
Made a hole for the flap servo linkage
Try fitting the flap servo
PostPosted: 27 Aug 2005 01:55 am
Aileron servo installed
Flap servo installed
Flap servo bay covered
Final touch on the wiring and install nose lead
Ballast inserted and ready for test fly tomorrow if weather permitted.
PostPosted: 27 Aug 2005 08:33 pm
Maiden it today in Ma On Shan.
Straight out without any tuning. Easy to control and pretty fast. It has very forgiving behaviour and definity I will use it for tomorrow F3F contest.
Close flypass with crow deployed
Angus also maiden his Aris today
Line up for wait on the airspace
See a movie how it performs
http://www.rcsail.com/aris28.avi
PostPosted: 28 Sep 2005 09:26 am
Stanly,
I enjoyed looking at your build of the aris, I also built one and lost it on the second flight due to false peak of the battery.
I have two more ordered!
I am trying to make arrangements to attend your F3F event November 4th thru the 6th along with Dan Field, we both live in California near LA.
Making travel arrangements with a large plane box is tough, it is 15?x 15?x 67?
The airlines all have different allowable cargo sizes.
I will be bringing my NYX and acacia II.
If we can over come the cargo problem we hope to be there.
Woody
PostPosted: 28 Sep 2005 11:25 pm
Thanks Woody for your interest in HK F3F Open as well as this thread regarding the Aris.
Sorry to know that you lose such a beautiful racer! Hope that you will fly the Aris again soon. It is certainly my top racer for the time being.
I made paper box with foam sheet to protect my gliders for air transport. Mind you that you need to arrange with the airline that you'll have large boxes before arriving in the airport. Usually, with the pressure from your travel agent, the airliner will give you a better weight allowance if you tell them earlier.
Good luck and looking forward to see you and Dan in Hong Kong.
PostPosted: 04 Oct 2005 02:39 am
I would like to know what clothing would be best suited for your weather and the race in November?
Looking forward to meeting you and to racing such a beautiful slope.
Woody
PostPosted: 04 Oct 2005 07:39 am
Congratulations on you new personal best and the new Hon Kong record of 36.15.
Out of 10 pilots with only 4 left flyable planes at the end of the day?
With the majority still smiling it must have been an exceptional event with a lot of personal best.
From the pictures I have seen of the slope it is grass with no rocks, what was the cause for so many damaged planes?
Woody
PostPosted: 04 Oct 2005 01:50 pm
Hi Woody,
November is the beginning of the dry season with strong northeast trade wind. This is the nicest season in a year. The temperature is around 23C in day time.
We had wind speed of average 45km/hr in the last F3F race in August. Although the landing area is full of grass, the turbulence near the ground proved to be too strong for some pilots. Most of planes got damaged in the nose section when the planes dived in the last second of the landing approach thus hitting the ground hard!
We are planning to move the landing zone to an area with less turbulence during the HK Open; however pilots have to walk about 100m for landing.
Cheers and looking forward to seeing you
PostPosted: 05 Oct 2005 08:40 am
Charging has become an issue, is there a local source I can buy a battery charging system?
I have a triton and would need a converter that will work on Hong Kong electrical outlets.
An automobile jump starter will work and is rechargeable.
Any suggestions?
Woody
PostPosted: 05 Oct 2005 11:48 am
Hi Woody,
I have a spare Futaba charger which you can borrow. What sort of charging cable outlet you need for your battery? The Futaba charger has a 9V output plug for the transmitter and a 4.8V plug for the receiver.
Regards
PostPosted: 05 Oct 2005 12:15 pm
I have the futaba 9ZWC2 transmitter and the planes have the regular male ends are the same as the servo leads to the receiver for charging.
The charging of two planes will take a lot of time using this system.
I would prefer to figure out how to use my chargers on you country
PostPosted: 22 Nov 2005 10:52 pm
早前幫機友訂的三隻 Aris 巳經到港,肥輝等
PostPosted: 27 Dec 2005 11:08 pm
今日馬鞍山一役傷亡慘重,我隻Aris要訂購配件脫胎換骨,才能重生!最近有些香港和台灣的飛友有興趣訂購 Aris,但由於人數尚少,運費較貴,請問仲有冇其他機友有興趣呀?
