It is currently Fri Jun 12, 2026 8:50 pm
Post new topic Reply to topic  [ 13 posts ]
PostPosted: Wed Jul 07, 2004 12:27 am
After a few months of DIY projects using coroplast & Styrofoam. My friend and I started to work on Blue Foam, Pink Foam and Fibreglass project. Hopefully, our first DIY slope racer will be born soon. 8)
PostPosted: Fri Aug 13, 2004 10:21 am
 Post subject: DIY glider
PostPosted: Fri Aug 13, 2004 10:26 am
PostPosted: Fri Aug 13, 2004 4:54 pm
我好似見個你隻机試飛,係唔係上個禮拜六清水灣個隻,不過好似無黃色隻翼.咁試飛試成黠呀?
PostPosted: Fri Aug 13, 2004 10:47 pm
Yes, I modified the wing and see if it could fly better in light wind condition.
 Post subject: BD5J
PostPosted: Wed Aug 18, 2004 2:50 pm
 Post subject: pic
PostPosted: Wed Aug 18, 2004 3:27 pm
http://www.hk-aviation.com/non-cgi/usr/25/25_86.jpg
PostPosted: Wed Aug 18, 2004 3:28 pm
 Post subject: Fuselage for mold making
PostPosted: Fri Oct 29, 2004 12:30 am
 Post subject: flat wing platform
PostPosted: Sat Nov 06, 2004 6:58 pm
[img]http://www.hk-aviation.com/non-cgi/usr/25/25_105_8.jpg
Anyone have any ideas on the performance of a flat platform wing? My meaning is - most slope racer left & right main wing joined together at a angle, maybe 170 degree. What will happen if I use MG06 airfoil with no angle at all. Hopefully you know what i mean.[/img]
PostPosted: Sat Nov 06, 2004 7:00 pm
PostPosted: Sun Nov 07, 2004 2:51 am
Dihedral is necessary for planes that use rudder for turning. If your plane is aileron equipped, dihedral can be set to 0 degree (flat wing). Dihedral adds lateral stability but also yaw-roll coupling (plane rolls when only rudder is applied). So pure aerobatic planes have zero dihedral. Other "not-so-aerobatic" aileron equipped planes usually have a few degrees of dihedral for lateral stability, while rudder only planes need very large (>7) dihedral for turning.
Good luck :wink:
PostPosted: Sun Nov 07, 2004 6:45 pm
Dear CM,
Thank you so much for the info. Very educational for beginner builder like me.
