It is currently Sat Nov 07, 2026 3:28 am
PostPosted: Fri Jan 17, 2014 9:42 am
Hi各位F3F飛友,
FAI已更新F3 RC Soaring Sporting Code,其中包括F3F,於2014聯賽開始,我們將使用2014版本,各位可以在此下載:
http://www.fai.org/downloads/ciam/SC4_V ... aring_2014
當中主要更新有兩項:
1,不可以在飛行其間提供飛行數據或天氣數據。
2,統一以"飛機 任何部份"替代"幾鼻"或"重心"。
5.8.2
2014 added:
Any technological device used to aid in supplying data of the air’s condition or direct feedback of the model’s flight status is prohibited during the flight. These devices include any transmission or receiving devices not used to directly control the model aircraft (telephones, walkie-talkies, telemetry of airspeed and altitude etc), temperature detecting devices (thermal imaging cameras, thermometers etc), optical aids (such as binoculars, telescopes etc), and distance/altitude measuring devices (GPS, laser range finders etc). Telemetry of signal strength at the aircraft receiver and state of the receiver battery is permitted. Use of corrective eyeglasses and sunglasses are permitted. I f an infringement of this rule occurs, the pilot will be disqualified from the contest.
5.8.6
2012:
h) the model (i.e. the centre of gravity) fails to pass above a horizontal plane, level with the starting area, within five seconds off exiting the course.
2014:
h) any part of the model aircraft fails to pass above a horizontal plane, level with the starting area, within five seconds of exiting the course.
5.8.9
2012:
Base A is the official starting plane. At Base A and Base B, an Official announces the passing of the model (i.e. the fuselage nose of the model) with a sound signal when the model is flying out of the speed course. Furthermore, in the case of Base A, a signal announces the first time the model is crossing Base A in the direction of Base B.
2014:
Base A is the official starting plane. At Base A and Base B, an Official announces the passing of the model (ie any part of the model aircraft) with a sound signal when the model is flying out of the speed course. Furthermore, in the case of Base A, a signal announces the first time the model is crossing Base A in the direction of Base B.
PostPosted: Fri Jan 17, 2014 10:05 am
堅叔個高科技thermal眼鏡唔合法喇! :lol: :lol: :lol:
PostPosted: Fri Jan 17, 2014 10:14 am
以後噤point簡單啲,揩到就得! :twisted:
PostPosted: Fri Jan 17, 2014 10:31 am
用XG8果班,快啲拆咗個高度計! :lol:
PostPosted: Fri Jan 17, 2014 10:34 am
即是話全機任何部分,包括機翼尖,尾翼觸point 都可按制!
PostPosted: Fri Jan 17, 2014 10:42 am
飛海灣,翼尖揩到都計! :twisted:
PostPosted: Fri Jan 17, 2014 10:48 am
WHAT ! !
我新買果個 XG8 重未開箱,就巳經變成非法產品 ! ? :evil:
回水呀 :x
講笑姐 ! 我買D先進產品,通常都係變o左 collector's item 先至囉返出黎用o架啦 :lol:
PostPosted: Fri Jan 17, 2014 10:55 am
我都買咗兩個高度計.. :shock:
PostPosted: Fri Jan 17, 2014 2:40 pm
係,但你點樣"尾翼觸point"?飄移入彎? :shock:
PostPosted: Fri Jan 17, 2014 2:55 pm
Split S
Users browsing this forum: No registered users and 31 guests
