It is currently Thu Sep 19, 2019 10:03 am
Post new topic Reply to topic  [ 20 posts ]
PostPosted: Thu Feb 04, 2010 11:23 pm
Just finished the fuselage today, will make the boom soon.
8) 8)
PostPosted: Thu Feb 04, 2010 11:24 pm
8)
The canopy :
8) 8)
PostPosted: Thu Feb 04, 2010 11:25 pm
Hi folks,
Here is my vacumum bagged tail. Only 5.4 gram with live hinge.
Thanks for Ah MAK lending the vacumum pump to me.
8) 8)
Dear all,
I finally make the boom today after the finish of the fuse 5 months ago.
Step 1:
Make some tools for rolling the video tape. A tapered wooden pole, and a stand
Modify a servo (make it turns like a motor) and put a switch on it. Also put a servo disc on the wooden pole.
Make a video tape dispenser for even pressure applies on the pole.
Step 2:
Wrapping the pole with video tape.
Step 3:
Cut the uni-carbon into size I need.
Step 4:
Wet out the frabic.
Step 5:
Put several layers of frabic together and roll them on the pole (No picture this time, as to my messy hands).
Step 6:
Put the pole on the motor set, and repeat step 2. This makes the video tape wrapping the carbon frabic and squeesing all the air and excessive epoxy (no picture again. Messy hands)
Step 7:
Soak the excessive epoxy away every 5 minutes.
Step 8:
Wait for the epoxy sets.
Step 9:
Removing the outter layer of video tape. The boom seems OK.
Will update later.
PostPosted: Thu Feb 04, 2010 11:26 pm
Hi folks,
The first boom I made was a bit heavy as I have used 6oz Uni-CF.
Having gotten some 3oz uni-CF, and some 1K CF, and finally made a light boom (this is the 3rd attemp):
Fitted to the fuse:
I think it looks better if the 1k CF is at the outter side :
15.5g (boom only) is not too bad, right ?
How do you guys think ?
Hi folks,
My vacaum bump is done and working fine:
8) 8)
PostPosted: Thu Feb 04, 2010 11:29 pm
Making the wings:
8)
PostPosted: Thu Feb 04, 2010 11:30 pm
The cutting bow:
8) 8)
PostPosted: Thu Feb 04, 2010 11:31 pm
The 'Feather cut' ruler:
:lol: :lol:
PostPosted: Thu Feb 04, 2010 11:32 pm
The product :
:lol: :lol:
PostPosted: Thu Feb 04, 2010 11:33 pm
I have two pairs of wings now:
PostPosted: Thu Feb 04, 2010 11:38 pm
Live hinged parts:
PostPosted: Fri Feb 05, 2010 12:00 am
Pong Pong! You so excellent! :shock:
PostPosted: Fri Feb 05, 2010 9:15 am
Hello Pong-pong. What is the material you used to make the templates?
PostPosted: Fri Feb 05, 2010 9:48 am
Ah Pong,
That's a very nice wing core :!: :D
Did you let the hotwire bow run by itself ?
PostPosted: Fri Feb 05, 2010 10:32 am
The templates were made with aluminium (1mm thickness).
Ah Mak,
The bow just like my son, need guidance and coaching. :lol: :lol:
BR,
PostPosted: Sat Feb 06, 2010 3:21 pm
8) 8)
2 oz glass at the leading edge,
6 oz of Uni-carbon as spar
3 oz peel ply as hinge
The skin is also 2 oz glass (already placed on the maylor)
8) 8)
PostPosted: Fri Feb 12, 2010 5:32 pm
Hi folks,
The wings are done.
(the fuse is still my old long-shot)
:P :P [/img]
PostPosted: Wed Feb 17, 2010 11:31 am
Why not taper the spars. Wing tip carries less load then the center :twisted:
PostPosted: Thu Feb 18, 2010 12:56 am
Your statement is right during normal flight time.
However, the tip have to bear a huge amount of load during launch. To be safe, I'd rather make it stronger.
P.S. I may be wrong.
