It is currently Fri Oct 30, 2026 11:28 pm
Post new topic Reply to topic  [ 19 posts ]
PostPosted: Thu Mar 15, 2007 10:36 pm
請問各位有玩開mini nyx嘅師兄以下問題:
1)新機裝邊隻servo 最fit. -- For wings, Futaba s3150(digital metal gear) 喺首選嗎?(價錢聽講幾貴)
2) 機身用Futaba s3101裝得落嗎?
3) 有其他要注意嘅事項嗎?
請各位俾啲經驗之談, Thanks !
PostPosted: Fri Mar 16, 2007 12:15 pm
You can try futaba s-3115 .It is new and fast and price around $2xx .It is your best choice!!!!
PostPosted: Fri Mar 16, 2007 1:21 pm
Be careful when you cut out the aileron servo wells. The wing spar of mine is within it and if you use a dremel tool you could inadvertently cut into the spars. I suggest you start from the aft (near trailing edge) and work slowly to the front lifting the skin looking under it to ascertain the spars' position in the process. Since the spars are sandwiched between thin layers of carbon fibre reinforcement even a slight cut would significantly reduce its strength. I screwed up mine and had to lay CF strip over the cut as a remedy yet without full confidence in it.
CT
PostPosted: Fri Mar 16, 2007 5:35 pm
Thanks Kin and CT for your valuable information !
PostPosted: Fri Mar 16, 2007 6:11 pm
I use Hitec 125 MG and my friend use 65MG with 6V, all are metal gears and very thin for the wings, not bad!
PostPosted: Sun Mar 18, 2007 12:11 am
隻翼用兩支hirobo直昇機牙桿35mm長,加一對鈇夾.fit到震,機身白色膠管廠方固定得太近前方.條金屬拉桿彎得太急,你要將條膠管用刀向後剷開D膠水約兩吋.等條垃桿早D離開旁边,盡量要順直.唔係以後垃桿太緊的話.SET中位非常難!!CG位如果在未上翼,單是机身.有齊电池接收,未落BALLEST 時,一般在中間四方形開口的前橫線(近前螺
PostPosted: Sun Mar 18, 2007 1:17 am
Ah Kin 好犀利渦!跟住仲有冇? (Set 機貼士呀)
PostPosted: Sun Mar 18, 2007 6:27 pm
嘩!阿堅,咩你教人set機和玩F3F就好似教人溝女和上床咁架! :x :x
情調靚、
做安全準備、
大門為你打開、
要盡情地插佢、
盡量要順直、
佢開心夠HIGH、
佢以經係你既人、
每日4次
嘩!教壞細佬! :x :x
PostPosted: Mon Mar 19, 2007 4:00 pm
你明知 Ah kin 教壞細路,重 qoute 佢D 野出黎 :evil:
我建議將 Stanley 同 Ah kin 一同列入黑名單
2 個月內唔準 post 野,同唔準比賽F3F。
只可以義務做 point A 同 point B 既 BB 手。 :twisted:
PostPosted: Mon Mar 19, 2007 5:40 pm
Stanley, 你明知 Ah kin 教壞細路,重 qoute 佢D 野出黎 :evil:
Kin Sir 無間道做得好 :o 引蛇出洞 :idea:
PostPosted: Tue Mar 20, 2007 12:45 am
吓!!錦都有不良意識?好喇下次用另一種表達方法喇!!我想另佢印象深D姐!不過要用文字嚟講解F3F,可能真係厚過电話簿呀!依家入門F3F既人真係唔多,原因肯定係價錢,我己經同大陸廠有共識,會生產一D要求唔係太高既入門3F机,成本可望在3-4000元左右,今年尾會有機出嚟!
PostPosted: Tue Mar 20, 2007 1:42 pm
kin wrote:
依家入門F3F既人真係唔多,原因肯定係價錢,我己經同大陸廠有共識,會生產一D要求唔係太高既入門3F机,成本可望在3-4000元左右,今年尾會有機出?!
不如出 2.5M 至 2.8M DS 機啦!
水準要專業級
價錢要入門級 2-3000元啦
以 DS 機既生命期計,包你貨如輪轉!
足夠係大陸開條高產量既生產線
PostPosted: Tue Mar 20, 2007 1:55 pm
呢兩條友 為老不專 教壞子孫,罰毛筆抄"養生保命集"十次 :evil: http://www.chinamorality.org.hk/big5/publication/04-charter01.htm
摘自 "養生保命集":
好色貪淫之人,猶如手執火炬,迎風而行,必然燒傷其身;又如見刀刃上之蜂蜜,以舌舔蜜,必然割傷口舌。
自古云:
求名者,因好色慾而名必敗;
求利者,因好色慾而利必喪;
居家者,因好色慾而家業必荒;
為官者,因好色慾而官職必失;
F3F者,因好色慾而機毀人亡。
所以,世間諸惡之中,以犯邪淫之報應最為慘烈、明顯、迅速。 . . . .
PostPosted: Tue Mar 20, 2007 7:26 pm
Hi everybody,
Thanks a lot for all of your valuable experience and information. I think Kin's message is really useful and precise. (i.e. Really Kin). I will try to put it into practice after the setup.
Now, the wings are done. However, I have no idea the best way to put the servo in the body. Should I just use Epoxy to attach the servos to the body ? Or, should I set something first.(e.g. put some wood to fix on the body first). Sorry for using English as I am not in HK at the moment (i.e. in Korea) and I forgot to bring the Chinese input pad.
Kindly provide some experience talk and thanks in advance to all of you senior pilot !
PostPosted: Tue Mar 20, 2007 7:50 pm
Ah Kin,
It's your turn again.
:!: :!: MIND YOUR LANGUAGE :!: :!:
PostPosted: Tue Mar 20, 2007 9:58 pm
嘩!我字字都是引用阿堅金句,都有罪? :lol:
OK
罰毛筆抄"養生保命集"十次
F3F者,因好色慾而機毀人亡
F3F者,因好色慾而機毀人亡
F3F者,因好色慾而機毀人亡
F3F者,因好色慾而機毀人亡
F3F者,因好色慾而機毀人亡
F3F者,因好色慾而機毀人亡
F3F者,因好色慾而機毀人亡
F3F者,因好色慾而機毀人亡
F3F者,因好色慾而機毀人亡
F3F者,因好色慾而機毀人亡
C.M.,其實我一直以此為誡,所以我
PostPosted: Tue Mar 20, 2007 11:00 pm
Hi C Tsang,
The following are the procedure I built my mini NYX. Hope that they are helpful to you.
http://hk.myblog.yahoo.com/my-F3F
PostPosted: Wed Mar 21, 2007 12:29 pm
C TSANG I will tell you some detail of the servo fixing tonight !
PostPosted: Wed Mar 21, 2007 5:45 pm
Thanks a lot for all those pictures and details. They are clear and easy to understand.
I could not write Chinese/Cantonese here as I didn't bring my Chinese input pad in Korea. (i.e. my Chinese input by keyboard is really slow).
However, I could still read from all of you in Chinese/Cantonese and so you could still write in Chinese/Cantonese (i.e. feel more lively, funny and interesting).
I will be back to HK soon and I will communicate with all of you in Cantonese then.
Wish all of you have good flight in the coming weekend !
( Note: I am quite missing the slope in HK as here is quite boring !)
Cheers !
Users browsing this forum: No registered users and 47 guests
