| RC Slope Soaring in Hong Kong http://www.rcsail.com/forum/ |
| Started to work on Blue/Pink foam & Fibreglass http://www.rcsail.com/forum/viewtopic.php?f=3&t=185 |
| Author: | WingDragon [ Wed Jul 07, 2004 12:27 am ] |
| Post subject: | Started to work on Blue/Pink foam & Fibreglass |
After a few months of DIY projects using coroplast & Styrofoam. My friend and I started to work on Blue Foam, Pink Foam and Fibreglass project. Hopefully, our first DIY slope racer will be born soon. |
| Author: | WingDragon [ Fri Aug 13, 2004 10:21 am ] |
| Author: | WingDragon [ Fri Aug 13, 2004 10:26 am ] |
| Post subject: | DIY glider |
| Author: | bchau [ Fri Aug 13, 2004 4:54 pm ] |
我好似見個你隻机試飛,係唔係上個禮拜六清水灣個隻,不過好似無黃色隻翼.咁試飛試成黠呀? |
| Author: | WingDragon [ Fri Aug 13, 2004 10:47 pm ] |
Yes, I modified the wing and see if it could fly better in light wind condition. |
| Author: | WingDragon [ Wed Aug 18, 2004 2:50 pm ] |
| Post subject: | BD5J |
| Author: | WingDragon [ Wed Aug 18, 2004 3:27 pm ] |
| Post subject: | pic |
http://www.hk-aviation.com/non-cgi/usr/25/25_86.jpg |
| Author: | WingDragon [ Wed Aug 18, 2004 3:28 pm ] |
| Author: | WingDragon [ Fri Oct 29, 2004 12:30 am ] |
| Post subject: | Fuselage for mold making |
| Author: | WingDragon [ Sat Nov 06, 2004 6:58 pm ] |
| Post subject: | flat wing platform |
[img]http://www.hk-aviation.com/non-cgi/usr/25/25_105_8.jpg Anyone have any ideas on the performance of a flat platform wing? My meaning is - most slope racer left & right main wing joined together at a angle, maybe 170 degree. What will happen if I use MG06 airfoil with no angle at all. Hopefully you know what i mean.[/img] |
| Author: | WingDragon [ Sat Nov 06, 2004 7:00 pm ] |
| Author: | CM Cheng [ Sun Nov 07, 2004 2:51 am ] |
Dihedral is necessary for planes that use rudder for turning. If your plane is aileron equipped, dihedral can be set to 0 degree (flat wing). Dihedral adds lateral stability but also yaw-roll coupling (plane rolls when only rudder is applied). So pure aerobatic planes have zero dihedral. Other "not-so-aerobatic" aileron equipped planes usually have a few degrees of dihedral for lateral stability, while rudder only planes need very large (>7) dihedral for turning. Good luck |
| Author: | WingDragon [ Sun Nov 07, 2004 6:45 pm ] |
Dear CM, Thank you so much for the info. Very educational for beginner builder like me. |
