It is currently Tue Nov 24, 2026 1:18 am
 Post subject: 新手CG問題!
PostPosted: Thu Jun 17, 2004 5:48 pm
可能係一個好簡單既CG問題.
好多機都要放好多鉛係機頭個CG先正確, 如果D機設計既時候做到個頭長D, 咁咪可以落小D鉛黎戥CG?
Thanks!
PostPosted: Thu Jun 17, 2004 5:56 pm
係,槓桿原理。
PostPosted: Thu Jun 17, 2004 6:10 pm
Yes, but there is a side effect. The moment of inertia is proportional to the square of the distance. This means if you double the length of the nose, yes you can save half of the nose weight. But at the same time the moment of inertia is four times of the original. This makes the plane difficult to control.
So better makes the tail lighter! :wink:
PostPosted: Thu Jun 17, 2004 6:14 pm
. . . But at the same time the moment of inertia is four times of the original. . . .
Sorry, should be TWO times as the mass is half of the original now.
PostPosted: Thu Jun 17, 2004 6:22 pm
Thanks CM, your Physics is really great!
So there should be a balance point between moment of inertia and nose distance? If weight is not an issue, an ideal plane should have no nose, and vice versa?
PostPosted: Fri Jun 18, 2004 12:39 pm
床板 :roll:
