| :o 新界人也有放機& http://www.rcsail.com/forum/viewtopic.php?f=3&t=133 |
Page 1 of 2 |
| Author: | Pierre Ng [ Wed Jun 02, 2004 6:34 pm ] |
| Post subject: | :o 新界人也有放機& |
最近發現在上水華山,有個車到又向南的斜坡,應該是適合玩滑翔機的地方!(由上水去都是十分鐘,車到門口,又沒有人,這裏有足夠大草地降落,斜坡所產生的升力不錯,執機又沒有困難) 星期日玩過一次都不錯. (有相Send上來比您們人看?) http://f1.pg.photos.yahoo.com/ph/vampir ... pg&.src=ph http://f1.pg.photos.yahoo.com/ph/vampir ... m=4506.jpg 地圖: http://f1.pg.photos.yahoo.com/ph/vampir ... m=e86f.jpg 由上水入文綿渡路,留意右面路口有一紅橋新村,轉入去行車五分鐘便到(入村后留意左面有一山路直上.) |
| Author: | Gary [ Thu Jun 03, 2004 8:38 am ] |
什樣去? |
| Author: | Pierre Ng [ Fri Jun 04, 2004 1:07 am ] |
上水華山(有相但唔知怎樣Send上來比您們人看?) |
| Author: | Billy [ Fri Jun 04, 2004 3:46 am ] |
Pierre Ng wrote: 上水華山(有相但唔知怎樣Send上來比您們人看?)
你e-mail比我,我幫你放上去 |
| Author: | Pierre Ng [ Mon Jun 07, 2004 1:32 pm ] |
| Post subject: | 星期六又去尋找 |
這次找到一個東風位在粉嶺,鄰近坪,從地圖尋正確位置. http://f1.pg.photos.yahoo.com/ph/vampir ... pg&.src=ph 高度: 235m 東風吹來沒有受到阻擋,斜坡所產生的升力不錯、可以足夠的上升氣流為滑翔飛行提供動力,!(由上水去都是十五分鐘,車到門口,又沒有人,這裏有足夠大草地降落,四米的機都在草地上落,執機又沒有困難) *****正確的坪輋東位!!!!!!!!!! http://f1.pg.photos.yahoo.com/ph/vampir ... m=3948.jpg *****更正之前的地圖!!! 呢處有D相: http://f1.pg.photos.yahoo.com/ph/vampir ... m=453a.jpg http://f1.pg.photos.yahoo.com/ph/vampir ... m=f339.jpg http://f1.pg.photos.yahoo.com/ph/vampir ... pg&.src=ph http://f1.pg.photos.yahoo.com/ph/vampir ... pg&.src=ph http://f1.pg.photos.yahoo.com/ph/vampir ... m=5d79.jpg http://f1.pg.photos.yahoo.com/ph/vampir ... pg&.src=ph 有興趣Call Me 一齊去玩! |
| Author: | Ah Pong [ Tue Jun 08, 2004 7:07 pm ] |
good work done, and it is really a good place to try. Call me before you go next time please. |
| Author: | KAM [ Wed Jun 09, 2004 12:36 am ] |
Hello !! Pierre and Ah Pong, Please also call me to join next time.It's a good place for soaring in summer. Ah Kam |
| Author: | Pierre Ng [ Wed Jun 09, 2004 1:13 am ] |
| Author: | Billy [ Wed Jun 09, 2004 4:39 am ] |
代客
| Author: | Gary [ Wed Jun 09, 2004 5:09 am ] |
真是好地方!大埔有無地點提供? |
| Author: | Willy (as guest) [ Wed Jun 09, 2004 9:09 pm ] |
Pierre,請問往(1)華山南位;及(2)坪輋東位的兩條馬路,普通私家車(非四驅)是否可輕易行駛? 掂的話,我想本週日試坪輋東位,橫掂天氣預告是東風。 |
| Author: | Steve [ Thu Jun 10, 2004 9:40 am ] |
| Post subject: | Flying sites at Wah Shan and Ping Che |
Willy (as guest) wrote: Pierre,請問往(1)華山南位;及(2)坪輋東位的兩條馬路,普通私家車(非四驅)是否可輕易行駛?
掂的話,我想本週日試坪輋東位,橫掂天氣預告是東風。 Hi Willy, I answer your question on behalf of Pierre. For the east-facing slope, there is a quite good condition single-way road from |
| Author: | Willy (as guest) [ Thu Jun 10, 2004 4:22 pm ] |
Quote: 這次找到一個東風位在粉嶺,鄰近坪,從地圖尋正確位置.
http://f1.pg.photos.yahoo.com/ph/vampir ... pg&.src=ph 高度: 235m 東風吹來沒有受到阻擋,斜坡所產生的升力不錯、可以足夠的上升氣流為滑翔飛行提供動力,!(由上水去都是十五分鐘,車到門口,又沒有人,這裏有足夠大草地降落,四米的機都在草地上落,執機又沒有困難) 我查過地圖,看不到該馬路可上到海拔235m,甚至該處亦無咁高的山頭。 Pierre 及 Steve 兄,請問是否要泊車在馬路盡頭,然後向西步行上山? |
| Author: | Steve [ Thu Jun 10, 2004 7:26 pm ] |
| Post subject: | East-facing flying site |
Willy, As you will see from below photo, it is the flying site and landing ground at the east-facing slope. We went to the flying site directly by a van. It isn't a normal car running road. It may be the reason you couldn't find it on map. Since there is a long stretch of rusted bud wire at the north side of the hill (facing ShenZhen), I believe the road WAS for the British Army / HK police to safeguard the border. The height provided by Pierre is measured by a friend's watch. It may not be accurate but it should be about there. http://f1.pg.photos.yahoo.com/ph/vampiresoul/detail?.dir=/Gliding&.dnm=d455.jpg&.src=ph |
| Author: | Willy (as guest) [ Fri Jun 11, 2004 6:01 pm ] |
Quote: It isn't a normal car running road. It may be the reason you couldn't find it on map.
噢,原來地圖未必顯示? 地圖顯示,往《上山吉乙》及《下山吉乙》,是不同的馬路,兩地並無馬路直接相通。 但Steve兄,你話︰「For the east-facing slope, there is a quite good condition single-way road from |
| Author: | Pierre Ng [ Fri Jun 11, 2004 7:02 pm ] |
| Author: | Pierre Ng [ Fri Jun 11, 2004 7:08 pm ] |
Billy wrote: Pierre Ng wrote: 上水華山(有相但唔知怎樣Send上來比您們人看?) 你e-mail比我,我幫你放上去 *謝謝您的幫忙,下次見面請教我* |
| Author: | rocky [ Fri Jun 11, 2004 11:54 pm ] |
今日去過華山睇黎,高度係90咪,用我個飛行錶。係虎地坳道入,岩岩過燈位就要轉入去架啦,再下個燈位如果直去就要入關口,左轉應該可以去其它地方掛。 去個南風位山頂有地方好掉定頭個度就係見到d相下面個條河,再継續去好似係一條不歸路,因為有地方掉頭,我就係咁源住條路去到坪輋度,不過我係抯電單車,源途都好斜,有d路係跟個山形建既,即係直上直落﹗﹗﹗ 呢條路都算係我抯咁石屎山路最靚一條,真係一個洞都冇,不過就好多時有則邊d草伸左出黎。 如果你想挑戰自己,咁可以抯畢全程,少d駕駛技術切以身試法,因為成條路係得一個掉頭位,加上只係夠一架車過,唔係講笑架。好多時上到山頂要睇通有冇車係對面落緊黎先好落山,唔係一架車係就係谷底用后波上番山都幾係野。 My advice:入就係上水入,出係坪輋出,不過你可以試下係坪輋入上水出都得,玩下用后波上山都幾過癮。如果係坪輋入,過浸會園留意對頭線有間好似叫龍威酒樓,咁你係度轉左入去就岩,一直入去致到同另一條路滙合,咁果度有個好似叫瑞安既細紅色牌仔,則跟就係上山條路,即上斜,有兩對廢左既大閘,咁你就入左岩既地方啦,因為有地圖,所以冇去到下山雞乙度睇睇。下次喇。 |
| Author: | Stanley [ Sat Jun 12, 2004 1:08 am ] |
喺地圖睇完都冇你所指的東風位,連較高的山也抓不到。但由上山雞乙地圖位置向南移多少少就有一個向東斜波,地勢有110米。睇真啲其實呢個斜坡離華山個南風位不遠還有小路可達。究景你們所指的東風斜坡是不是其實就是這個呢?
| Author: | Pierre Ng [ Sat Jun 12, 2004 1:19 am ] |
Dear:Rocky 你今天去了正確南位,及坪輋東位了(大約在你落山前的地方),我和Ricky用貨Van就係咁源住條路去到坪輋,由於中原的地圖沒有清楚的山路,而之前說的東位(下山雞乙)只是說係下山雞乙的路口轉左入去,和你去過的地方一樣,而沒有什麼下山吉乙東位的地。 我地這條路只行過一次,但因中段真是如你所說,所以都是小心地原路來原路走吧! 明早去坪輋東位,有興趣Call Me 一齊去玩! |
| Author: | Pierre Ng [ Sat Jun 12, 2004 2:02 am ] |
| Post subject: | 正確的坪輋東位!!!! |
正確的坪輋東位!!!!!!!!!! 更正之前的地圖!!! http://f1.pg.photos.yahoo.com/ph/vampir ... m=3948.jpg 而南位之前的地圖正確. |
| Author: | Guest [ Sat Jun 12, 2004 2:14 am ] |
從地圖睇呢個應該是東南徧南風位,並非正東風位! |
| Author: | Pierre Ng [ Sat Jun 12, 2004 4:20 pm ] |
Guest wrote: 從地圖睇呢個應該是東南徧南風位,並非正東風位!
一個山頂有東南北比你玩的!!! |
| Page 1 of 2 | All times are UTC + 8 hours |
